Old 12-10-2007, 04:12 PM
RobertSmith RobertSmith is offline
Lintel installation
Home inspection
Old 12-10-2007, 04:39 PM
Scott Patterson's Avatar
Re: Lintel installation
Heck if the home is 30 years old and it had not done anything, I would not even worry about. Would not even make my report.
Scott Patterson
Old 12-10-2007, 05:11 PM
Kevin Barre Kevin Barre is offline
I agree w/ Scott. Generally, there isn't a lintel even used with arches anyway as they are pretty good at supporting themselves. That said, the flatter they are, the less effective they are at that job. But in this case, the brick load above is minimal. If there's been no movement in 30 years, I don't expect much if anything now. Barring some outward force acting on it that's not present now, of course.
Old 12-15-2007, 07:35 AM
John Goad John Goad is offline
Arches will support themselves after the mortar has set up. Until then supports (such as wooden forms cut to the shape of the arch) are used, or should be.
With the one pictured where a lintel is used I suspect it did not have a stiffleg support in place midway & sagged in the middle, causing the ends to bow up.
Wider door & window openings will also sag if not supported until the mortar has set.
Clarksville Home Inspection
JW Goad
Similar Threads
Skylight installation Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 17 12-17-2007 05:33 PM
Window Lintel Sagging Clay White Building Envelope: Home Inspection and Commercial Inspection 3 11-19-2007 06:27 PM
Window Installation Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 1 11-02-2007 04:26 PM
East TN installation Jack Feldmann Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 09-23-2007 07:39 PM
Lintel Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 5 05-29-2007 05:20 PM
vB.Sponsors
Ad Management by RedTyger
