Old 12-11-2007, 04:13 PM
Joseph P. Hagarty's Avatar
Joseph P. Hagarty Joseph P. Hagarty is offline
Interior Wall Framing (Door Opening)
Interior Wall Framing (Bedroom Doors).
Openings are Framed without jack studs. Are they required?
Joseph P. Hagarty
Main Line Inspections, Inc.
http://www.householdinspector.com
Home inspection
Old 12-11-2007, 04:55 PM
Re: Interior Wall Framing (Door Opening)
No. There is no load (no header) which needs to be supported. All that top framing does is hold drywall up. That wood framing (without jack studs) is stronger than interior non-load bearing metal framing.
Old 12-11-2007, 05:11 PM
charles buell charles buell is offline
I agree with Jerry and would add that doubling of the framing helps with the installation of trim---especially the wider stuff.
Charles Buell
Old 12-11-2007, 05:13 PM
Michael Thomas's Avatar
It does not matter that the lower chord is here?
Old 12-11-2007, 05:23 PM
Carl Eisen Carl Eisen is offline
No, the cord in that postion does not matter.
Trusses, in general there are exceptions, are free spanning from exterior wall to exterior wall. The interior walls are nothing more than partition walls. They all could be removed and it would have no impact on the performace of the truss.
Knew of a company in my area that would build a handful of homes leaving out the interior walls. They would go back to these homes and install the partion walls during bad weather. Kind of like today
Carl Eisen
West Bend, WI
  #6 (permalink)
Old 12-11-2007, 05:24 PM
Trace the load path from the top down.
If the truss is clear span (does not bear on interior walls), then there is no need for headers or jack studs since the purpose of headers is to redirect the load around the door, window, etc. to the studs on either side.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #7 (permalink)
Old 12-11-2007, 05:26 PM
Sorry Carl, you typed faster than I. Ditto what Carl said.
Allen, Texas 75002
  #8 (permalink)
Old 12-11-2007, 05:32 PM
Thanks.
Joseph P. Hagarty
Similar Threads
Fireplace opening dan orourke Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 2 12-03-2007 07:17 PM
Door (?) opening over stair Clay E White Building Envelope: Home Inspection and Commercial Inspection 2 09-23-2007 07:20 PM
Multiple vents through one opening Jeff Eastman Built-In Appliances and Systems: Home Inspection and Commercial Inspection 12 06-06-2007 07:45 PM
Interior or Exterior:Boulder Paul Kondzich Building Interior: Home Inspection and Commercial Inspection 10 05-10-2007 08:04 PM
Opening at bottom of guardrail dan orourke Building Interior: Home Inspection and Commercial Inspection 5 05-07-2007 06:29 PM
vB.Sponsors
Ad Management by RedTyger
