Old 04-20-2008, 01:29 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Toilet clearance to door
As regards clearance to the front, is intermittent interference by a swinging door a code violation, or merely idiotic?
Home inspection
Old 04-20-2008, 02:33 PM
Jerry McCarthy's Avatar
Re: Toilet clearance to door
IRC Chart for bathroom fixture clearances.
Construction Consultant
Old 04-20-2008, 06:08 PM
Jim Zborowski Jim Zborowski is offline
Only a problem if you're siting there when somebody whips the door open.
Old 04-20-2008, 06:30 PM
Quote:
Looks like a 'private bathroom', i.e., like one you would find in a house , and in which case it is 'mostly likely' that the door would be closed and locked when on the toilet. Thereby not creating a problem.
Old 04-20-2008, 07:38 PM
Michael Larson's Avatar
Michael Larson Michael Larson is offline
The door isn't the problem.
It looks to be far less than a 30" space side to side.
  #6 (permalink)
Old 04-20-2008, 09:10 PM
Quote:
Those are clearances to fixed objects, it's a movable door I'm wondering about.
  #7 (permalink)
Old 04-21-2008, 08:41 AM
Quote:
Originally Posted by Michael Thomas View Post
(from the other Jerry)
Michael,
The door is not a problem, if that is a multi-person bathroom, there would be a door to that stall, and, if it is a single-person bathroom, that door would be expected to be closed and locked (for the privacy for which there is a lock on that door) - which would preclude someone from 'just opening the door and intervening with someone using the toilet'.
End result - that door clearance is not a problem.
  #8 (permalink)
Old 04-21-2008, 10:11 AM
I believe the IRC code clearly shows a minimum clearance of 21" in front of the WC (UPC 24") or am I missing something?
  #9 (permalink)
Old 04-21-2008, 05:39 PM
WCJ,
Has always been 21" in the codes I've had and worked under.
  #10 (permalink)
Old 04-21-2008, 06:28 PM
Randy Aldering Randy Aldering is offline
The clearance should be 21 inches in front. The door does not count. If there is a problem, it is poor design, or knees obstructing the operation of the door, or a privacy lock failure.
Randy Aldering, RHI CHI
Housesmithe Home Inspection
www.housesmithe.com
  #11 (permalink)
Old 04-21-2008, 07:06 PM
While we are on this topic, it is a good time to bring up something specifically related to it:
That 30" wide space, 15" to each side of center, and the 21" clearance in front of, are applicable at the same time.
I.e., that 30" wide space extends 21" in front of the front of the bowl.
I had many expensive custom homes where there was a 45 degree angled wall which cut across that 30" wide by 21" in front of space - all to 'make the corner look better by being a 45 instead of a 90', but which ended up creating a clearance problem at the toilet.
The builders had two choices: a) correct it (doing so after the fact could be quite expensive, what with expensive wall treatments, etc.); b) give money to the client of give them something else of value for which my clients would 'be satisfied'.
Of course, the latter always happened, an after the fact upgrade to something, and I reminded my clients that such *did not negate the problem* when they go to sell. Not that they cared about that ... *they got their* "freebie" from the builder, they would then tell their buyer 'not fixing it, that's the way it was permitted and constructed' (at which time the buyer would want some 'compensation' proving again that 'nothing is free').
  #12 (permalink)
Old 04-22-2008, 08:59 AM
OR, cut two slots in at the bottom of the door to accommodate knees and lower legs and then of course one could always ride the WC "side-saddle."
  #13 (permalink)
Old 04-22-2008, 12:03 PM
Corey Friedman Corey Friedman is offline
Michael,
This may or may not be a problem. It all depends on choice of newspaper. Sun-Times or Chicago Tribune. The Reader may also pose a problem.
Corey
  #14 (permalink)
Old 04-22-2008, 02:04 PM
Paul Kondzich Paul Kondzich is offline
The only question I have is this: Micheal, how did you take that picture without getting your feet in it??
Paul Kondzich
www.altitudehomeinspection.com
  #15 (permalink)
Old 04-22-2008, 05:27 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
The cream floats to the top!
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Home inspection
Similar Threads
Toilet clearance Dan Harris Plumbing System: Home Inspection and Commercial Inspection 4 04-02-2008 02:49 PM
Toilet Rough-In ? Rick Hurst Plumbing System: Home Inspection and Commercial Inspection 34 03-12-2008 07:56 PM
in the toilet... Help Anthony Alderman Plumbing System: Home Inspection and Commercial Inspection 11 08-30-2007 02:44 PM
Teeny toilet Dom D'Agostino Plumbing System: Home Inspection and Commercial Inspection 6 08-07-2007 09:01 PM
Toilet position Ed Bliss Plumbing System: Home Inspection and Commercial Inspection 12 05-05-2007 11:52 AM
vB.Sponsors
Ad Management by RedTyger
