Old 06-17-2008, 07:05 AM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Correct term for thermal window "gasket"
What is the correct term for the rubber "gasket" which secures a thermal window pane into its frame?
Also. come to think of it, is it "window pane" or "windowpane"?
Old 06-17-2008, 07:24 AM
Rick Hurst's Avatar
Re: Correct term for thermal window "gasket"
It's window pane.
The seal itself is just known as the air seal I believe. Maybe not.
Old 06-17-2008, 08:56 AM
This is the component in question... of course, its the only one that's not labeled...
Old 06-17-2008, 09:17 AM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is online now
Quote:
Thermal pane sealing gasket [ works for me. ]
File Type: jpg 20001001_Window_Glass_Repair_page003img003.jpg (23.1 KB, 25 views)
Billy J. Stephens HI Service
Rick Hurst's Avatar
Michael,
Google "swiggle seal"
No, its not a joke.
Maybe thats what your looking for.
  #6 (permalink)
Old 06-17-2008, 11:55 AM
Quote:
Originally Posted by Rick Hurst View Post
Michael,
No, its not a joke.
Nope. That's a type of "insulating glass edge seal system" (from their web site).
I would go with "weather seal" when referring to the outer "rubber "gasket" which secures a thermal window pane into its frame".
There are "wet" seals and "dry" seals. "Dry" seals are those rubber one which are placed into the frame, while "wet" seals are "wet" applied sealant which is forced into the joint from a sealant (caulking type) gun, frequently those guns are pneumatically powered.
  #7 (permalink)
Old 06-30-2008, 07:39 PM
Steven Turetsky's Avatar
Steven Turetsky Steven Turetsky is offline
Hi Guys,
How has everyone been?
It is called "glazing vinyl". It is a one piece "u" shaped strip that fits over the IGU (insulated glass unit) and the frame is pushed over it.
When glazing flush glazing (store fronts) there are two separate strips. One gets installed into the frame prior to the glass lite or IGU being installed and the second gets installed after the lite is in place.
If you ever need any, go to crlaurence.com
homeinspectionsnewyork.com
eifsinspectionsnewyork.com
Similar Threads
T&P failed test ... seller's agent "unhappy" Nolan Kienitz Plumbing System: Home Inspection and Commercial Inspection 15 03-03-2008 04:23 PM
"Frost Proof" Sill Cock Information Michael Thomas Plumbing System: Home Inspection and Commercial Inspection 15 12-10-2007 09:25 PM
"Fireblock" or "separation" Jeff Eastman Building Interior: Home Inspection and Commercial Inspection 9 10-16-2007 06:27 PM
"Shrink-swell soil" article. Did inspector miss this? Scott Dana Sub-Structure: Home Inspection and Commercial Inspection 4 10-15-2007 08:49 PM
Overheard At Home Depot: "Pointy Bolts" Bruce Breedlove General Chit Chat: Home Inspectors & Commercial Inspectors 16 06-04-2007 05:23 AM
vB.Sponsors
Ad Management by RedTyger
