Old 06-30-2008, 06:18 PM
Peter Wigle's Avatar
Peter Wigle Peter Wigle is offline
Basement Floor - sloped
This concrete basement floor drops about 3/8" per foot over a roughly 7' run. It is 'normal' over the rest of the basement. The slope runs down from the perimeter - about 2' to the right of the dryer (where the sump is located) - until a point about even with the left side of the washer (where the floor drain is located).
The concrete is level with the sump rim at that end of the basement. Is it possible the sump was placed too high and the concrete crew forced the floor to match the height of the sump rim at that point, then let it drop relatively quickly to match the floor drain? Would concrete hold a slope like that whike curing? I would have expected a stepped-up area just around the sump, if this was the problem.
Home inspection
Old 07-01-2008, 05:29 AM
David Banks David Banks is offline
Re: Basement Floor - sloped
Peter. Any more pics? Overall view. Concrete will hold a slope like that, just depends how stiff you lay the concrete. 3 slump or less would hold in your situation.
Dave
Similar Threads
Basement Walls Tom McDonnell Structural Components: Home Inspection and Commercial Inspection 5 02-27-2008 05:12 PM
Basement inspection Rick Cantrell Sub-Structure: Home Inspection and Commercial Inspection 0 01-01-2008 02:04 PM
Finishing a basement Bruce Thomas Sub-Structure: Home Inspection and Commercial Inspection 8 08-13-2007 06:14 PM
Basement egress wayne soper Building Interior: Home Inspection and Commercial Inspection 13 06-15-2007 04:36 PM
Clogged basement floor drain. clayton bucek Plumbing System: Home Inspection and Commercial Inspection 5 06-10-2007 12:18 PM
vB.Sponsors
Ad Management by RedTyger
