Old 08-26-2009, 01:05 PM
Jerome W. Young Jerome W. Young is offline
garage door opener
ever seen one installed off center? is this a problem?
Home inspection - The Cost Of Business.
Old 08-26-2009, 01:17 PM
Brandon Whitmore Brandon Whitmore is offline
Re: garage door opener
I would want to see the manufacturers installation instructions on that one, but............
If the door springs are adjusted properly, what could it hurt? That would just be like someone manually opening the door off center.
Old 08-26-2009, 01:21 PM
Jerry Peck's Avatar
Quote:
Almost always is a problem as that can cause the door to not go down straight, the door goes a little crooked, which upset the automatic reverse sensitivity, which then needs to be adjust to allow the door to close, with makes it not operator properly.
That is almost all installation instructions state to install the door at the center of the door (mainly for the above reason, but also likely because that is the only way the opener was tested, listed and labeled).
I recall (I think) seeing one brand which allowed off-center installation but only with an extra kit you had to get from them which would compensate for the operator not being centered (to compensate for that twist effect of pushing down on only one side of the door).
When the opener cannot be centered on the door, then the better operator is one which mounts directly above the door and lifts it straight up from the bottom roller points, which allows the door to roll up and back on those tracks.
From one Craftsman garage door operator installation instructions:
- 1. With door closed, located and mark the vertical centerline of the garage door. Extend line onto header wall above door.
- 2. Locate height for header bracket by opening door to highest point of travel as shown. Draw an intersecting horizontal line on header wall 2" above high point. This height provides travel clearance for top edge of door.
Last edited by Jerry Peck : 08-26-2009 at 01:30 PM. Reason: added last part from installation instructions
Old 08-26-2009, 01:40 PM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
JP: I have not seen this. If you recall it, pass the info on, please.
JP: True, but much pricier.
JP: All that I have seen starts just like that.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
Old 08-26-2009, 10:43 PM
And when there isn't enough room front to back just use this handy conversion kit
www.crawfordinspections.com
  #6 (permalink)
Old 08-26-2009, 11:11 PM
Or, just install the automatic opener in front of the beam so that the door will not fully open. I just had that on a high end 5k sq. ft. home 2 days ago Any vehicles lower than 6'4" were good to go.
  #7 (permalink)
Old 08-27-2009, 08:55 PM
Dom D'Agostino Dom D'Agostino is offline
Liftmaster/Craftsman allows up to a 4 foot variance from the center mark, and has done so for many years. (Limitations apply, but typically they work fine.)
Dom.
  #8 (permalink)
Old 08-27-2009, 11:49 PM
Michael Schirmer Michael Schirmer is offline
If it worked when you tested it - I would just say that this installation might not be ideal. Opening the door from off-center can sometimes cause the door to bind in the track. Should this occur, contact a garage door service technician for repairs or to approve/certify this current installation.
Safe writing can be Ambiguous if need be...
  #9 (permalink)
Old 08-28-2009, 10:28 AM
Jerry Peck's Avatar
And writing like that does not help your client at all - which IS why you are there.
What you wrote is, you think, going to protect you, but that IS NOT why you were there. Besides, not fulfilling your part of the contract is not going to protect you, if your report does your client no good, your report is worthless, which means your contract is worthless.
  #10 (permalink)
Old 08-28-2009, 10:32 AM
MS: Ambiguous writing in this business is never safe.
  #11 (permalink)
Old 10-01-2009, 03:09 PM
William Zoller William Zoller is offline
I just inspected an off center garage door opener. The opener was loose at the point of connection at the door. I defected it citing stress on the opening mechanism due to being off center. I believe the brand was LiftMaster.
  #12 (permalink)
Old 10-01-2009, 03:14 PM
Quote:
WZ: I write up each one that is off center. I have yet to see a Chamberlain manual which allows it. Get the model number and use this link to verify:
LiftMaster instruction manuals, LiftMaster garage door openers and operators instruction manuals
  #13 (permalink)
Old 10-01-2009, 03:36 PM
Rick Hurst's Avatar
Here's one I came across the other day mounted off to the side. Seems the attic door laddler was cut directly in the center of the garage ceiling making installation of the door opener off.
The seller mentioned that the garage door opener installer had mentioned that if the door opener was a 1/2hp. it would operate with no problems.
A 1/3hp. would not.
It still made my report.
  #14 (permalink)
Old 10-01-2009, 04:29 PM
Jim Luttrall Jim Luttrall is online now
Speaking of garage door operators (notice I did NOT call it an "opener") I remembered the story a while back of the kid that was killed by an improperly grounded detached garage and opener when I saw this one today.
This was a 1960's house with a two wire branch system that had the opener plugged into a adapter which plugged into a homemade two wire lamp cord stapled to the ceiling and down the wall to a brand new three wire outlet. I knew it could not be grounded and just for kicks brought out my non-contact voltage tester and sure enough, it light up like a Christmas tree everywhere on the door, opener, and tracks. Bare foot on the wet concrete and it could light up your life.
Of course the electrician will be there anyway since they had both a Zinsco and a Federal Pacific Stab-Loc panel.
Allen, Texas 75002
  #15 (permalink)
Old 10-01-2009, 04:31 PM
Gunnar Alquist's Avatar
Quote:
Rick,
What about the attic ladder?
We have enough youth, how about a fountain of Smart?
  #16 (permalink)
Old 10-01-2009, 04:49 PM
Rick Hurst's Avatar
Gunnar,
You talking about the fire separation comments?
  #17 (permalink)
Old 10-01-2009, 05:09 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Jerome,
FWIW, I read somewhere that a somewhat off-center operator will work on a door with torsion spring, but often will not work on a door with a tension type springs.
For Genie operators "Center of bracket must be on centerline of door..."
Chamberlain allows installation up to 4' off the centerline. http://www.chamberlain-diy.com/doity...s/114A3060.pdf
  #18 (permalink)
Old 10-01-2009, 09:20 PM
Rick Hurst's Avatar
Check out this spring from today.
  #19 (permalink)
Old 10-01-2009, 10:11 PM
Gunnar, You talking about the fire separation comments?
Yeah. Around here, if you have a ladder into the garage attic, it is generally the separation wall.
  #20 (permalink)
Old 10-02-2009, 05:11 AM
Quote:
Originally Posted by Michael Thomas View Post
Jerome,
MT: Chamberalin actually says, in the document you posted:
The opener should be installed above the center of
the door. If there is a torsion spring or center
bearing plate in the way of the header bracket, it
may be installed within 4 feet (1.22 m) to the left or
right of the door center.
That does not give the installer carte blanche to install it off center due to the presence of a beam, attic stair unit, or a fly on the ceiling.
  #21 (permalink)
Old 10-02-2009, 06:30 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
there's these???
Sidemount Door Opener - patented sidemounted garage door opener
Liftmaster model 3800 RJO sidemount garage door opener | Liftmaster Garage Door Part 3800
Model 3800 DC Motor Side Mount Opener
NEW idrive Garage Door Operator by Wayne-Dalton
Residential-Commercial-Construction-EIFS-Infrared Thermography
  #22 (permalink)
Old 10-02-2009, 09:37 AM
BA: Correlation is not causation.
  #23 (permalink)
Old 10-02-2009, 10:36 AM
Steve Duchene Steve Duchene is offline
If, and I said if, a door is properly balanced the location of the opener does not have to be directly centered. The opener is a helper and is not designed to lift the weight and horsepower has no bearing. But, how many doors are properly balanced. I have installed many doors and openers in a past life (before the easy life of an inspector) and there are occasions where off- center is the only way some could be installed.
I checked a nine foot door yesterday that was so unbalanced that i could hardly lift it, though the opener did not seem to struggle.
  #24 (permalink)
Old 10-02-2009, 11:45 AM
Greg Lambke Greg Lambke is offline
There is no problem mounting a Garage Door "OPERATOR" ( It also closes the door ) off center as long as adequate support is provided accross the top of the door with the GDO attached through the support. Support is ussually provided by adding an addition steel angle.
There are even kits to install one operator for two doors with the unit mounted between the double doors.
The affore mentioned conditions are not at all uncommon.
  #25 (permalink)
Old 10-02-2009, 11:57 AM
GL: No, there is no problem mounting a garage door operator off center so long as the manufacturer states there is no problem.
Home Inspector Essentials. The BEST prices for inspection tools.
  #26 (permalink)
Old 10-02-2009, 04:43 PM
Jerry Peck's Avatar
This deserves repeating: (bold is mine)
Quote:
  #27 (permalink)
Old 10-07-2009, 06:27 AM
Cobra Cook Cobra Cook is offline
Rick, did you also write up the fact that the trim around the door was touching the ground?
  #28 (permalink)
Old 10-07-2009, 06:35 AM
Also, remember an inspection is not a warranty, at a given day at a given time. some openers can be allowed to be offset and operate for many years with no problems. If the door was opening and closeing at the time of the inspection and the safeties were working where is the problem? I wish i had a crystal ball as some inspectors do to look in the future of what could happen just so i could pick the correct lottery numbers.
  #29 (permalink)
Old 11-06-2009, 07:19 PM
biglebowski biglebowski is offline
shouldnt we be at least making the observational note that this installation could potentially have problems in the future and monitor it for that even if it is working properly at the inspection?
Similar Threads
Is reinforcement needed prior to installing a garage door opener? Jeff Barnhouse Exterior Systems: Home Inspection and Commercial Inspection 0 07-20-2009 11:10 AM
vehicle door opener needs GFCI? John Arnold Electrical Systems: Home Inspection and Commercial Inspection 3 06-08-2009 05:53 PM
Door Opener Box Greg Frazier Electrical Systems: Home Inspection and Commercial Inspection 5 05-13-2008 06:52 PM
Garage Door/Opener Inspection-Thibodaux, LA Ronald Gould Employment: Home Inspectors & Commercial Inspectors 0 07-31-2007 09:36 AM
Garage Auto Opener Button Location Jeff Eastman Built-In Appliances and Systems: Home Inspection and Commercial Inspection 2 06-22-2007 06:16 PM
vB.Sponsors
Ad Management by RedTyger
