Old 09-06-2009, 01:44 PM
Len Couey Len Couey is online now
Location of gas shut off valve for appliances
As stated in IRC 2006 2420.5 equipment shut off valve, I would like to know what is considered accessiable, is it just where the appliance(stove) can be moved out then the valve is accessable.??
Len Couey
HomeGauge Reports
Old 09-06-2009, 02:51 PM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
Re: Location of gas shut off valve for appliances
Quote:
Len Couey
LC: Yes. As long as you can reach the valve by moving the appliance it is considered accessible.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
Old 09-06-2009, 03:19 PM
Thanks, AD I have had a running battle with the client that has become pretty heated on their part. I have my code certs but have not been able to convince them of the code.
Len C
Old 09-06-2009, 03:35 PM
One of the many things I've learned here is that those shut-offs are for service and not for emergencies. That usually clears it up in people's minds. I've had the same topic come up with clients in the past.
www.crawfordinspections.com
Jerry Peck's Avatar
G2420.1.3 (409.1.3) Access to shutoff valves. Shutoff valves shall be located in places so as to provide access for operation and shall be installed so as to be protected from damage.
ACCESSIBLE. Signifies access that requires the removal of an access panel or similar removable obstruction.
An "appliance" is a "similar removable obstruction" in that an access panel may screwed and secured in place, whereas the appliance can be slid in and out.
  #6 (permalink)
Old 09-23-2009, 02:21 PM
Philip Ngai Philip Ngai is offline
Hi, Len. Could you describe what the client is thinking?
Personally, I like my clothes dryer's gas valve above the dryer just like the washer's hot and cold water valves. I don't claim that this is required by code but as long as cost is not an issue, it seems clearly superior to me, don't you agree?
  #7 (permalink)
Old 09-23-2009, 02:33 PM
Jerry Peck's Avatar
Quote:
No Len, but I disagree.
That would make the valve, the gas line, and / or the gas connector susceptible to physical damage. As long as it is below the top of the clothes dryer, then somewhat higher up on the wall than near the floor would be okay, as long as the valve was not stubbed straight out from the wall and allowed the gas connector to connect to the valve parallel with the wall and not have to make a 90 degree bend in the gas connector.
But I'm not even sure I would want it up there.
What is the difference between a clothes dryer and a range, where would you like to see the valve for the gas range? Up above the gas range? Why or why not?
Same reasoning and logic should apply to those two appliances.
  #8 (permalink)
Old 09-23-2009, 02:45 PM
Quote:
The better analogy is between the washer and dryer, as the top of the dryer does not get hot and greasy like a range.
Would you put your washer's water supply valves low on the floor, behind the washer where they are impossible to access without moving the appliance?
I understand that moving the appliance is allowed by code, but isn't it better to not have to if you have a choice?
  #9 (permalink)
Old 09-23-2009, 02:50 PM
Jerry Peck's Avatar
I've never seen a gas washer, so that analogy does not make sense to me.
With the washer you are talking about WATER, with the dryer you are talking about GAS, two really different things with really different requirements, and really different outcomes should there be a leak.
  #10 (permalink)
Old 09-27-2009, 08:54 PM
John Kogel's Avatar
John Kogel John Kogel is offline
I tell clients the valve is for service techs. "If you smell gas, don't touch anything, leave the house, call the fire dept. and they will turn off the main valve outside."
  #11 (permalink)
Old 09-28-2009, 02:21 AM
Rob Omstead Rob Omstead is offline
I agree with John and make your client aware of the location of the main shutoff outside.
HomeGauge Reports
Similar Threads
Strange gas shut-off valve Jeff Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 11 09-08-2009 08:17 PM
Hot Tub/Spa shut-off valve Dave Hahn Plumbing System: Home Inspection and Commercial Inspection 1 01-17-2009 03:59 PM
Clarification on location of gas appliances Kevin Luce Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 8 03-17-2008 01:43 PM
gas shut off valve Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 6 07-19-2007 07:28 AM
Gas shut off valve location Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 07-03-2007 10:53 PM
vB.Sponsors
Ad Management by RedTyger
