Old 10-30-2009, 07:27 AM
Linda Swearingen Linda Swearingen is offline
Gas oven carbon monoxide
It seems like gas ovens all discharge carbon monoxide (except the ones with automatic vent fans to the outside, which isn't many). Is there any sort of industry standard as to how much is too much? I realize that they can't burn 100% until they warm up some, but I've seen some that don't back down to under 8 or 10 ppm, and a few that were so high (200+ppm) that they are absolutely unsafe to operate as they are. But where do we draw the line?
Home inspection - The Cost Of Business.
Old 10-30-2009, 09:28 AM
John Dirks Jr's Avatar
John Dirks Jr John Dirks Jr is offline
Re: Gas oven carbon monoxide
I always recommend that CO detectors be installed whenever any fossil fuels are used in a home.
If for whatever reason the CO levels get high enough to present a hazard, the alarm should warn the occupants.
John Dirks Jr - Arundel Home Inspection LLC
Maryland Home Inspection - Maryland Home Inspectors - Maryland Radon Testing - Baltimore County Rental Inspection
Old 10-30-2009, 12:10 PM
Bob Harper's Avatar
ANSI Stds. allowd for up to 800ppm from gas ovens. Any you just thought it was the tryptophan from the turkey making you sleepy at Thanksgiving.....
John, the operative words in your post were "should" warn and "high enough to present a hazard".
Present stock off the shelf CO alarms listed to UL 2034 are proven unreliable at best. So much for the *should* part. They are designed to ignore levels under 70ppm leaving you exposed. They even state on their packaging if you are elderly, have small infants or children or certain medical conditions, you may need "additional protection". So why am I buying this piece of junk in the first place?
There are two low level CO monitors on the market that are reliable and provide adequate protection, thus they are NOT listed to UL 2034 for single station monitors or UL 2075 for central station monitoring (which use the same alert levels): The CO Experts and the NSI 3000.
Try this test: crack the door to the oven then set to 'broil' and monitor CO. All that cool room air rushing into the top of the heat spreader plate will cool the gases causing CO formation. You can also demonstrate the effects on a range top with a pot of cold water.
yes, ovens and ranges *should* be ventilated but unfortunately they don't *have* to be.
Bob
Old 10-30-2009, 04:16 PM
DavidR's Avatar
DavidR DavidR is offline
Quote:
Bob
They should be banned IMHO.
No place for them in any type of construction anymore.
Old 10-30-2009, 04:34 PM
Gunnar Alquist's Avatar
Quote:
Originally Posted by DavidR View Post
They should be banned IMHO. No place for them in any type of construction anymore.
David,
Ummm... ovens and ranges? How are we supposed to cook?
We have enough youth, how about a fountain of Smart?
  #6 (permalink)
Old 10-30-2009, 04:48 PM
DavidR's Avatar
Quote:
Originally Posted by Gunnar Alquist View Post
David,
I get by just fine on electric.
  #7 (permalink)
Old 10-30-2009, 06:03 PM
Rick Hurst's Avatar
A true Chef or someone who really enjoys cooking knows that gas is the only way to cook.
  #8 (permalink)
Old 10-30-2009, 06:12 PM
Quote:
Right On! Ban the electric wimps!
  #9 (permalink)
Old 10-31-2009, 06:23 AM
Dennis Krouse's Avatar
Dennis Krouse Dennis Krouse is offline
Thank you Rick and Gunnar. I couldn't agree more!
  #10 (permalink)
Old 10-31-2009, 06:56 AM
Rick Cantrell Rick Cantrell is offline
Bob
It has been years since I read up on CO detectors, so my opinions are likely to be out of date.
My understanding of CO detectors is that they are unreliable, and pretty much useless in the home, even the professionally installed type that I have access to. I don't recommend them.
You said "There are two low level CO monitors on the market that are reliable and provide adequate protection".
Which two?
Rick Cantrell
  #11 (permalink)
Old 10-31-2009, 07:26 AM
DavidR's Avatar
So you guys that use gas have made sure your ovens are operating safely and have low level CO monitors installed?
If they are vented and operating safely not a problem, otherwise I fail to see why you would want one in a building.
A real chef uses an open flame but I don't bring that inside either.
  #12 (permalink)
Old 10-31-2009, 08:27 AM
Bob Harper's Avatar
Quote:
Originally Posted by Rick Cantrell View Post
Bob
Which two?
Rick, finish my sentence. Both I refer to ARE very reliable, unlike the listed alarms and they do alert at low levels unlike listed alarms. The NSI 3000 is available only if you take Day 1 of the NCI Co & Combustion Course. You can buy the CO Experts online from George Kerr.
Guys, understand where DavidR is coming from. Aside from teaching the NCI CO & Combustion course, he is a practicing professional HVAC tech who does check gas ovens so he knows first hand what he's talking about. I've tested a few dozen and found CO issues to one degree or another with all. Understand the ventilation is needed on electric ranges and ovens as well. The aerosolized food particles and humidity should be exhausted to the outdoors regardless of fuel burned.
Those professional chefs cook over professional ovens and ranges with massive exhaust fans rated in the thousands of CFMs sucking that kitchen inside-out. Ever tried to open a door to a commercial kitchen? Some of the worse depressurized spaces in the world. I've had commercial kitchen fans affect direct vent gas fireplaces. Had to install a $10K makeup air system.
The lack of a proper interlock with the gas burner was a direct cause of a CO poisoning event near me that sent people to the ER twice from the same grocery store caused by the same bake oven. What saved the day was the personal CO monitor/ alarm carried by the paramedics who responded to an old lady collapsed at the bake counter. It went off at 35ppm. I have carried a personal CO monitor for years and it has alerted me to hazardous environments, including being in traffic. How do you know you are not walking into a toxic environment every day? You guys should be wearing a personal 4 in 1 alarm: % LEL, CO, O2, H2S. That's what my next personal alarm will be.
Bob
Bob
  #13 (permalink)
Old 10-31-2009, 09:01 AM
JORY LANNES JORY LANNES is offline
Great subject however I think a bigger question needs to be asked. HOW MANY INSPECTORS CHECK FO CO LEVELS?
In a informal study of my ASHI chapter less than 50% of the members check for carbon monoxide as part of there standard inspection.
Testing for CO is not an Illinois or ASHI standard of practice.
I have found over the years several unsafe hot water heaters and furnaces only because of my CO tester.
Should the SOP be changed?
Jory Lannes
Lannes Group Inspections Inc. Chicago, Il.
847 733 7705 jory@lannesgroup.com
  #14 (permalink)
Old 10-31-2009, 09:11 AM
"Rick, finish my sentence. Both I refer to..."
Sorry Bob, I was reading it wrong. When you said CO Experts I thought that meant, people that are carbon monoxide experts in general and NSI3000 was a standard.
Thanks for clearing that up.
Rick Cantrell
  #15 (permalink)
Old 10-31-2009, 09:50 AM
DavidR's Avatar
Yes the SOP should be changed Jory, kudos to you for being proactive and testing without being made to!
You're setting a good example for those in your chapter that aren't aware of what they could be walking into.
  #16 (permalink)
Old 10-31-2009, 09:53 AM
DavidR's Avatar
Bob
Bob
I really like the idea of the 4 in 1 Bob, Christmas might come early.
The other item with commercial kitchens and the pressure imbalances due to improperly balanced hoods is the effect they have on the water heaters sitting in those very kitchens.
Many kitchen fires and CO poisonings have been attributed to this depressurization.
  #17 (permalink)
Old 10-31-2009, 03:30 PM
Bob Harper's Avatar
Just another example why you should wear a 4 in 1 monitor: BREAKING NEWS !!!! - Two badly burned in gas explosion - Carmi, IL - The Carmi Times
This was two HVAC techs who were injured. One is a grizzled veteran and friend of a frequent contributor over on HVAC-Talk.com where I found this. There was an LP tank in the yard to a furnace in the crawl space. He thought he had the tank shut off. No shutoff within 6ft. of appliance (now you know why code requires this). They went under to service and light pilot. 3rd degree burns on face and hands but they think he will live. They did not smell the gas so they ASSumed they were ok. Either the gas was below their noses or it was a case of 'odor fade'. Regardless, a 4 in 1 set to alert at 20% of the LEL could have warned them of the hazardous environment where they could have escaped unhurt. BTW, for LP gas, the LEL is about 4,300 ppm.
If there is a venting problem to where CO2 is being released into the room it will displace the O2 so an oxygen deficient space is a problem for people and combustion.
With all the busted stink pipes/ traps in basements and the low IDLH & PEL for hydrogen sulphide, this is cheap protection.
Bob
  #18 (permalink)
Old 10-31-2009, 06:00 PM
So, who believes it's a bad idea to recommend CO detectors/alarms?
  #19 (permalink)
Old 10-31-2009, 06:18 PM
So why were they trying to light the pilot if they thought the tank was off???
  #20 (permalink)
Old 11-01-2009, 11:08 AM
What is a personal 4 in 1 alarm: % LEL, CO, O2, H2S.? Who is the manufacture,where are they sold, approx price?
Jory
Jory Lannes
  #21 (permalink)
Old 11-02-2009, 10:11 AM
mathew stouffer mathew stouffer is offline
Well said Rick, gas is king.
  #22 (permalink)
Old 11-06-2009, 03:58 PM
DavidR's Avatar
None of you guys that are for the Kevorkian cooking style have said if you've tested your gas ranges yet.
Similar Threads
Carbon monoxide tester Stephen G Sheldon Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 6 06-06-2009 03:41 PM
Carbon Monoxide Detectors Patrick McCaffery H E L P ! 6 04-08-2009 04:26 PM
carbon monoxide tester JORY LANNES Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 63 03-03-2009 08:58 PM
Carbon Monoxide detector 1 ft. above floor Ron Bishop Building Interior: Home Inspection and Commercial Inspection 33 03-03-2009 07:56 AM
Carbon Monoxide / Gas Furnace Joseph P. Hagarty Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 03-02-2009 04:44 PM
vB.Sponsors
Ad Management by RedTyger
