Garage door lock (that is installed inside) has been disabled intentionaly per realtor since it is an automatic garage door. Is it suppossed to be that way? Thanks,
Matt unsure as to any standards. But If you have ever try to open to door with the lock in place and latched you would understand why to disable. Damn near cost me $800.00 to replace a garage door. I try to recommend to my clients that it be disabled to prevent acciental damages.
TREC tells you in our SOP that the lock should be written up as a repair if the lock is present on an overhead garage door with an opener.
Its a no-brainer.
You have to write it up if the lock is present. If the agent disabled it to prevent it from locking, she saved you some keystrokes on your report writing.
All Rights Reserved. Hann Tech Marketing Link / InspectionNews.com / InspectionNews.net - No part of InspectionNews.net may be reproduced in any way, or by any means, without the prior written permission of InspectionNews.net. Use of any index or listing Software for the purpose of constructing a mailing list, creating promotional materials or producing a printed or electronic catalog of any kind is expressly forbidden without the prior written permission of InspectionNews.net - All text, graphics and design on InspectionNews.net is copyright by Hann Tech Marketing Links. Ad Management by RedTyger
