Old 04-15-2007, 06:01 PM
dan orourke dan orourke is offline
food disposer
Home inspection
Old 04-15-2007, 06:06 PM
Re: food disposer
If it is not used, it should still be plugged from the factory knockout.
It it is not still plugged, you should see water everywhere when the disposal is in operation with the water on.
You could also see or feel inside the port for the solid plug.
Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 04-15-2007, 09:38 PM
Tim Moreira's Avatar
Tim Moreira Tim Moreira is offline
Re: food disposer
Put your screw driver in that hole. If you feel it hit something solid just inside the opening, if so, that is the factory knock out Jim mentioned.
That is for the dishwasher drain hose. If not used, the knockout should still be in place. If not, everyone will know about it like Jim said when they turn on the disposer.
Old 04-15-2007, 09:44 PM
Re: food disposer
Quote:
Do so a little carefully, you don't want to accidentally knock the knock out out.
Old 04-17-2007, 05:49 AM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Re: food disposer
Those unknown holes will get you in trouble.
I stuck a screwdriver in the disposer opening once to find the knock out had been removed, but it was clogged up with enough texture and paint material that it wouldn't even leak.
It leaked very well after I poked my screwdriver through it.
Painters. Gotta love them.
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
  #6 (permalink)
Old 04-17-2007, 02:37 PM
Re: food disposer
Rick,
So what did you say in your report? Failed under test???
  #7 (permalink)
Old 04-17-2007, 03:26 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
Re: food disposer
Use you pinkie!
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
Food for thought Mike Schulz General Chit Chat: Home Inspectors & Commercial Inspectors 9 04-15-2007 10:09 PM
vB.Sponsors
Ad Management by RedTyger
