Old 05-21-2008, 09:25 AM
Gene South Gene South is offline
WHO KNOWS WHAT THE TREC SOP SAYS ABOUT DRYER VENTS TERMINATING INSIDE GARAGE
Anyone know what the TREC (Texas) SOP's say about a dryer vent terminating inside an enclosed attached garage space ?
Gene
Old 05-21-2008, 09:43 AM
Michael Larson's Avatar
Michael Larson Michael Larson is offline
Re: WHO KNOWS WHAT THE TREC SOP SAYS ABOUT DRYER VENTS TERMINATING INSIDE GARAGE
Quote:
Gene
Does it really make a difference what TREC says.
It's just plain stupid.
I'm curious. Does TREC get into this type of obvious defect?
Old 05-21-2008, 10:03 AM
Scott Patterson's Avatar
Gene
Yep, TREC should have little to do with calling it wrong. Goes against all good building practice and codes. But, having said that it is also common in many parts of the South and West to see it.
Scott Patterson
Old 05-21-2008, 11:41 AM
(v) Ducts, vents (including dryer vents) and
flues. The inspector shall:
§§535.229(q)(7)-(y)
73
(1) report as in need of repair deficiencies
such as damaged ducting or insulation, improper
material or improper routing of ducts
where visible and accessible;
(2) report as in need of repair the absence of
air flow at all accessible supply registers in the
habitable areas of the structure;
(3) report as in need of repair deficiencies in
accessible duct fans and filters;
(4) report as in need of repair deficiencies in
installation, such as gas piping, sewer vents,
electrical wiring or junction boxes in the plenum,
returns or chases or improper sealing, where
visible;
(5) report as in need of repair deficiencies in
the flue system components;
(6) report as in need of repair a flue or vent
pipe that does not properly terminate; and
(7) report as in need of repair deficiencies in
materials used for the venting systems.
(w) Specific limitations for ducts and vents.
The inspector is not required to do the following:
(1) determine the efficiency, adequacy or
capacity of the systems;
(2) determine the uniformity of the supply of
conditioned air to the various parts of the structure;
(3) determine the types of materials contained
in insulation, wrapping of pipes, ducts,
jackets, boilers and wiring;
(4) operate venting systems unless ambient
temperatures or other circumstances, in the
reasonable opinion of the inspector, are conducive
to safe operation without damage to the
equipment; or
(5) operate a unit outside its normal operating
range as reasonably determined by the inspector
This is just copied from the TREC web site where the SOP is posted. Red is mine.
Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
Old 05-21-2008, 06:55 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
... And from the "Proposed" TREC SOP it says:
535.232 SOP: Minimum Inspection Requirements for Appliances
(j) Dryer Vents. The inspector shall report as Deficient:
(1) improper routing and length of vent pipe;
(2) inadequate vent pipe material;
(3) improper termination:
(4) the lack of a dryer vent system when provisions are present for a dryer; and
(5) damaged or missing exterior cover.
Please NOTE and REMEMBER that the above snippet is from the "PROPOSED" TREC SOP. IF/WHEN approved it will replace what Jim posted.
Cheers - Nolan E. Kienitz, PMP
Dallas Home Inspector
www.NolansInspections.com
  #6 (permalink)
Old 05-21-2008, 07:04 PM
Nolan,
Man, that's not one I would want to have to deal with ... you would literally have to have the installation instructions for each dryer you inspected (or was connected to the dryer exhaust duct you were inspecting) in your head, in your computer, or in your hand to be able to address the "improper ... length" of the dryer exhaust duct.
Similar Threads
a/c condensate terminating at sink drain Jerome W. Young Plumbing System: Home Inspection and Commercial Inspection 28 05-20-2008 07:43 PM
Range hood vents to attached garage Michael Thomas Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 9 01-31-2008 05:38 AM
Laundry Room and Dryer Exhaust Vents Clay White Built-In Appliances and Systems: Home Inspection and Commercial Inspection 51 10-31-2007 07:37 AM
Combustion Air Vent terminating at Roof Top Clay White Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 1 10-17-2007 03:34 PM
Garage Vents Charles Smith Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 8 07-11-2007 09:45 AM
vB.Sponsors
Ad Management by RedTyger
