Results 1 to 9 of 9
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Breakfast Anyone?
    Short of lugging pots and pans around on inspections, how do you inspect an induction cooktop element for operation?
    Default Re: Breakfast Anyone?
    What, you don't carry a test pan?
    If in an occupied house, I will use their pan, otherwise, I will disclaim. I know of no accurate method of testing.
    Orlando, FL
    Agreed....
    Dom.
    And You Call Yourself an Inspector. .
    You know that scrap tin tab you threw away ... that 2" circle of steel which was cupped?
    Yep, put a little water in it, set it on the burner, and watch it boil.
    Of course you will also want to lay a paper towel under it to absorb the spill/splash over.
    I used to bring a plastic cup to put water in to test microwave ovens with, a steel cup would work for the induction cooktops and ranges.
    A.D. Miller Guest
    JP: Good idea. Thanks.
    I just check the pictures on the wall to make the kids look 'healthy' and assume the stove works.
    A.D. Miller Guest
    All of the ones I have seen still get warm to the touch when turned on. Some of them you have to depress the button in the center of the burner.
    FK: This was a flat glass top, no center button and no heat rise.
    Healdsburg, CA
    I used toi put a metal pot filled with water in the microwave, turn it on full and watch the fun!
