    wes owens's Avatar
    wes owens Guest
    Default dishwasher drain
    Inspected a 9 year old house today that had a 1/2 inch CPVC drain line from the dishwasher to the sink.
    It was a new double drawer dishwasher.
    Are there any dishwashers that allow this, or should they all be 3/4 inch drains?
    Thanks,
    Wes
    Mar 2008
    Charlotte NC
    Default Re: dishwasher drain
    Quote Originally Posted by wes owens View Post
    Thanks,
    Wes
    I don't think I have seen a solid pipe (PVC or CPVC) drain line from the DW to the sink. Do you have pic's?
    wes owens's Avatar
    wes owens Guest
    No.
    I just noted it and recommended replacing with 3/4 inch.
    The only thing that makes me wonder is that it's a double drawer unit. Maybe they discharge separately and smaller amounts? Best thing would be to check the manual or run the model number and get to it online. That's where the best info will come from.
    I don't know about a 1/2" drain line, but the DW nipple on the sink tail peice is not 3/4", it's 5/8" OD.
    Jerrod Christian's Avatar
    Jerrod Christian Guest
    most double drawer dw have a drain from both drawers that tie into a rubber wye fitting that is connected with spring clamps with a 3/4" female side to tie onto a disposal or dw tailpiece
