Thread: copper high loop
11-12-2009, 12:46 PM #1
copper high loop
A first for me. Never seen a copper high loop before.
11-12-2009, 01:42 PM #2
Re: copper high loop
That is supposed to take care of water hammer.
11-12-2009, 01:54 PM #3
11-12-2009, 01:56 PM #4
DOAK!!!!!!!!!!!
11-13-2009, 05:37 PM #5
1/2" is not acceptable by the plumbing code for a drain for the dw.It should be 3/4" which is what the inlet for the disposal inlet is.
11-13-2009, 05:45 PM #6
11-13-2009, 05:56 PM #7
Copper tubing is expensive but most dw come with a flexible drain hose or you can buy a rubber hose at any home improvement store which is what the older dw came with.
