Results 1 to 12 of 12
Thread: Heating element manufacturers
10-25-2010, 11:14 AM #1
Hello Gents!
Since you guys are such a wealth of information, I was hoping someone would have a direct line to a manufacturer of residential oven elements.
I have some technical questions for a manufacturer, or if one of you know, perhaps you could help.
I need to know the exact composition of a baking oven heating element in a residential oven. I had tied contacting Whirlpool, Sears, and a couple of distributors, without luck.
Thoughts?
Cheers!
CaoimhÃ*n P. Connell
Forensic Industrial Hygienist
Forensic Applications Consulting Technologies, Inc. - Home
AMDG
10-25-2010, 12:01 PM #2
Re: Heating element manufacturers
I don't know what the heating elements are composed of, nevertheless, I'm concerned that they may be a source of radon and/or black mold. Or asbestos. Possibly lead.
I assume that's your concern as well, CaoimhÃ*n.
It goes without saying, of course, that they contribute to global warming.
10-25-2010, 01:23 PM #3
10-25-2010, 02:14 PM #4
10-25-2010, 06:10 PM #5
10-25-2010, 06:42 PM #6
Calrod (TM) sealed elements or NiChrome.
10-25-2010, 06:51 PM #7
You're not likely to find it. These parts are sent out to bid and are manufactured primarily in China. The heating wire is usually 304 stainless (although not always) with a ceramic insulator, resistance powder, and tube. The resistance powder is usually magnesium oxide, but the manufacturer can specify otherwise. The ceramic insulator and tube materials are usually not specified by composition; instead they is specified by heat dissipation and other performance characteristics. As a result, the manufacturer usually has the ability to specify the material as they see fit.
10-25-2010, 07:15 PM #8
10-25-2010, 08:11 PM #9
Thanks, Gents for the laughs and the good info.
I’m working on a fire investigation; looking at human exposures during the fire, which according to credible reports was exclusively the heating element. I’ve done dozens of metal fires in the past, but I never heard of heating elements catching fire!
And yes, John, there was conclusive proof that for a short period of time, the temperature of their word was definitely elevated!
Thanks again.
Cheers!
AMDG
10-26-2010, 05:21 PM #10
10-26-2010, 09:12 PM #11
03-01-2011, 10:56 PM #12
You may go to the oven manufacturer and ask your quires to him or her. They would provide you with valuable suggestions...
