Thread: What it is???
    Jul 2009
    Spokane, WA
    Default What it is???
    90's model GE microwave and conventional oven (over/under). Inside the conventional oven on the front upper right side is a rod that protrudes through the interior wall of the oven and extends approx 8 to 10 inches. I know it is not the thermostat as I identified it at the back upper left. Any help identifying this would be appreciated. I told the client that its for roasting a hot dog. Then I admitted that I had no fricken idea. Said I know how to find out though.
    Garland, TX
    Default Re: What it is???
    Bill,
    did you get model #
    you may want to try here
    I suspect that appendage is a heat sensor for the broiling element, no?
    New York
    Could it have at one time been connected to the spreader brace on the element, providing lateral support?
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Jun 2010
    Vancouver
    might be something that has broken in time and the full extent of what it is, is no longer there. As long as it don't poke the cherry pie I would just stay away from it. )
    Robert Alfred Moller's Avatar
    Robert Alfred Moller Guest
    That is a temperature probe used when cooking which gets inserted into whatever to find internal temperature.
    Example cook till 140 F. internal.
