Thread: What it is???
10-06-2011, 12:13 AM #1
What it is???
90's model GE microwave and conventional oven (over/under). Inside the conventional oven on the front upper right side is a rod that protrudes through the interior wall of the oven and extends approx 8 to 10 inches. I know it is not the thermostat as I identified it at the back upper left. Any help identifying this would be appreciated. I told the client that its for roasting a hot dog.
Then I admitted that I had no fricken idea. Said I know how to find out though.
10-13-2011, 04:38 AM #2
Re: What it is???
Bill,
did you get model #
you may want to try here
10-13-2011, 09:01 AM #3
Re: What it is???
I suspect that appendage is a heat sensor for the broiling element, no?
10-13-2011, 04:10 PM #4
Re: What it is???
Could it have at one time been connected to the spreader brace on the element, providing lateral support?
10-14-2011, 02:37 AM #5
Re: What it is???
might be something that has broken in time and the full extent of what it is, is no longer there. As long as it don't poke the cherry pie I would just stay away from it.
10-17-2011, 08:51 AM #6
Re: What it is???
That is a temperature probe used when cooking which gets inserted into whatever to find internal temperature.
Example cook till 140 F. internal.
