    Jan 2011
    Mississauga, Canada
    Default Electric dryer venting
    Hi Guys,
    Dryer currently vented using flexible plastic to the outdoors. It appears to be clogged.
    I know the manufacturer recoommends ridid metal venting. The current plastic vent is enclosed in an interior wall (6 to 8 feet) before it get to the outside wall. My question is, should I replace the current plastic vent with rigid metal, and run the rigid metal vent within the interior wall as before?
    Somehow I wonder if this is safe. The Sears manual says rigid metal vent, but does not say if it should be in open space or if it can be within the wall.
    Thanks,
    Inspection Referral SOC
    Mike Rodney
    Ontario, Canada
    Default Re: Electric dryer venting
    Quote Originally Posted by michael Rodney View Post
    Hi Guys,
    Thanks,
    This topic is presently located in the "Built-In Appliances" technical area, and as written appears to be a DIY question, esp. since H.I.'s generall don't do handy-work, they Inspect & Report. I anticipate the discussion will be moved to the "Questions from Home Owners, Home Buyers & DIYers" discussion area in the near future.
    Mesa AZ
    A while back he stated that he is a new inspector in this post.
    http://www.inspectionnews.net/home_i...d-windows.html
    It's very possible it's something he found on a recent inspection.
    If we ask a question that HG determines it sounds like it's from a non inspector, should all of us post in the
    "Questions from Home Owners, Home Buyers & DIYers" discussion area ?
    www.inspectaz.com
    Orlando, FL
    No clothes dryer manufacturer allows the use of flexible vinyl exhaust material.
    You can't run flexible exhaust or transition duct of any kind within walls-only smooth walled metal within walls or between floors.
