    Default Question regarding commercial freezers
    at what temperature (high range) , commercial freezers are set to go to when in defrost mode?
    Dec 2009
    Florida
    Default Re: Question regarding commercial freezers
    Quote Originally Posted by Stephen Lagueux View Post
    Suggest that you get the make/model number of the freezer, contact the manufacturer, discuss with them. If you have access to the manual your answer may be there.
    Dec 2007
    Chico,Ca
    Commercial freezers have timers to go into defrost mode, depending on on the situation it could be set to defrost 4X a day. By "commercial" I mean reach in type, or walk in freezers.
    thanks for the inputs guys,
