Thread: moisture meter
    Chicago IL
    Default moisture meter
    Hey guys, I need a new moisture meter. So many more choices. Who likes what they are using. I would appreciate recommendations. Thanks
    www.aic-chicago.com
    Default Re: moisture meter
    Tramex Moisture Encounter
    or
    Protimeter SM
    I use Protimeter, and carry my old original moisture meter as back up which is a Lignomat which I purchased in 1992!
    David Banks's Avatar
    David Banks Guest
    Tramex Moisture Encounter Plus
    Aaron Miller's Avatar
    Aaron Miller Guest
    Markus:
    Depends on what you will be using it for. For general use I agree with a number of the others that the Tramex Mositure Encounter is a good choice. I also like my Delmorst J-4, J-2000 and Tramex Professional Moisture Meter for different applications. Then there's the Tramex Wet Wall Detector for EIFS.
    Aaron
    I own both a Tramex and and a Protimeter, use both almost every inspection. The pin extension cable on the PM is *really* handy for getting out to rafter tails, into tight areas around rim joists and the like. BTW you can (per verbal from GE tech support) make an extension cable for the PM and make a calibration chart by comparison with the direct pin readings.
    Chicago IL
    Thanks for the suggestions guys, that helps a lot.
    Markus
    www.aic-chicago.com
    Also
    USE OF ELECTRICAL MOISTURE METERS
    Paper: Use of electrical moisture meters
