Old 04-25-2008, 02:36 PM
Kendall Goad Kendall Goad is offline
Commercial Inspections
Just curious
I was contacted by a client asking if I would be interested in doing an inspection on a vacant commercial building and was curious if as a certified home inspector if this is allowed.
They only want the the roof inspected and a visual inside to make sure there are no major problems visible.
Thanks for any and all replies,
Kendall
Old 04-25-2008, 02:49 PM
Scott Patterson's Avatar
Re: Commercial Inspections
Quote:
Originally Posted by Kendall Goad View Post
Just curious
Kendall
Do you know anything about commercial buildings? If not you might want to defer this to an inspector in your area who knows about commercial buildings.
You should use ASTM E-2018 for the inspection as a guideline.
Scott Patterson
Old 04-26-2008, 05:11 PM
I agree with Scott E-2018 is the way to go as a baseline.
As far as licensing I suggest you check with your State regs. Your HI license probably won't cover it but also won't need to. There may not be a commercial insp license required. Often times in commercial transactions parties are deemed to know what they are doing.
If you aren't experienced in commercial, that's OK. Don't give the job away. Collaborate with someone who has experience and learn from it, split the fee.
847/736-9975
Markus Keller
Similar Threads
Commercial Vince Santos General Chit Chat: Home Inspectors & Commercial Inspectors 1 04-12-2008 12:06 PM
Commercial Inspections mathew stouffer Building Interior: Home Inspection and Commercial Inspection 4 03-26-2008 09:48 AM
Commercial Kitchen Floor Matt Fellman Building Interior: Home Inspection and Commercial Inspection 9 02-29-2008 07:40 AM
Commercial Exterior Lighting Scott Lynch Electrical Systems: Home Inspection and Commercial Inspection 2 10-05-2007 04:15 PM
Commercial inspection questions Fritz Kelly Attic Areas: Home Inspection and Commercial Inspection 3 08-21-2007 12:00 PM
vB.Sponsors
Ad Management by RedTyger
