Thread: stab lock
    Jason Schmidt's Avatar
    Jason Schmidt Guest
    Default stab loc
    Can some one determine the amps on this one. it has 2, 600 volt wires and one to the neutral bus bar. i hope i insert the pictures right.
    Attached Files Attached Files
    Ron Bibler's Avatar
    Ron Bibler Guest
    Default Re: stab lock
    No photos in the post..
    Best
    Ron
    Jason Schmidt Guest
    Got the picture in this time.
    Since it's a FPE panel, it's tempting to answer ZERO AMPS, because how can it have any current flowing when it's sitting in the trash out on the sidewalk?
    However, see where it says AL 2 AWG on one of the hot legs? That would be 100 amp service.
    Georgetown, KY
    Since it's a FPE panel, ... in the trash out on the sidewalk?
    Quote Originally Posted by Erby Crofutt View Post
    It needs to be replaced anyway.
    Let's presume, in its current (pun intended) and existing condition, as shown in the photo that this is the "service equipment" - which it is with the meter below feeding it.
    There are 12 + 1 (having one empty space for another breaker) *Main Disconnects* in there. Only up-to-a-maximum-of 6 are allowed.
    Also note the overheated white wires, those coming off the breakers ...
    There there are the more-than-one neutrals in the neutral terminals.
    Then there is that large hole in the back with some contraption around the wires going through an extra-super-large knock out with brick and mortar showing.
    And then ...
    Let's see, Erby said it needed to be replaced and John said when you do to put it in the trash out on the sidewalk ...
    Yep, those are the best recommendations.
    The only recommendation which could improve on that would be to have the installing electrician do so at his own cost - no cost to anyone else - except he is likely long since retired, maybe not even on this Big Blue Planet Earth with us anymore either.
    Jason Schmidt Guest
    Thank you so very much. I hope you all have a great day.
