Results 1 to 3 of 3
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Abandoned and Discontinued Cables
    Is there an NEC citation for the removal of abandoned or discontinued NM cables from main distribution or remote panelboards?
    Oct 2008
    Tulsa, OK
    Default Re: Abandoned and Discontinued Cables
    I did not find anything. Only references cables installed under chapter 6, 7 and 8.
    None for NM cables. Only for low voltage Class 2 and similar circuits (unless tagged and labeled for future use).
