    Default electrical support
    My question is - are these sufficient supports for 100 amp services? If they were 200 amp, for instance, would 2X10s be needed? Maybe a S.E. should be called for "further evaluation"?
    Talking Re: electrical support
    John:
    You have shamed me! I would have never considered the necessary 2x support.
    Great picture.
    Joe Tribuzio's Avatar
    Joe Tribuzio Guest
    Default Re: electrical support
    oh gosh those two post should be painted with fire proof paint, set 48 inches into the ground and there should be a fire stop halfway up, plus a outdoor smoke detector with a water fountain nearby for a drink of cool water
    John, I hope you also mentioned that those 2x4s should be GFI 2x4s due to the exterior installation.
