Results 1 to 1 of 1
02-09-2009, 12:22 PM #1
Dwelling unit outside lighting outlets
Since the 2008 NEC does not require AFCI or GFCI protection for the lighting outlet outside each grade level access. How is everyone writing this one up?? Or are you assuming it is covered?
Similar Threads:"Get correct views of life, and learn to see the world in its true light. It will enable you to live pleasantly, to do good, and, when summoned away, to leave without regret. " Robert E. Lee
