Results 1 to 3 of 3
    Oct 2008
    Tulsa, OK
    Default Gasoline Dispenser
    I was inspecting another home. 10 feet from the side of the garage is a gasoline dispenser sitting over an underground tank. It is fed with NM cable direct buried. Other then the NM cable being a violation( it has been this was for 30 years) is the dispenser required to follow article 514?
    F.I.R.E. Services
    Jeff Remas's Avatar
    Jeff Remas Guest
    Default Re: Gasoline Dispenser
    Yes for any changes, repairs or alterations if existing. It meets the definition of Motor Fuel Dispensing Facility.
    Oct 2008
    Tulsa, OK
    Yup--It is pretty amazing what you may find. I made them disconnect and remove the pump before authorizing a meter installation for a re-energize.. It is probably now installed again but I don't have to look at it. I just put another red pin on the map for FD training sites in the county.
