Results 1 to 2 of 2
    Jeff Remas's Avatar
    Jeff Remas Guest
    Default Residential Lightning Protection System Grounding
    Is/Are the lightning system grounding electrode(s) allowed to be used as the required building or structure grounding electrode system?
    Oct 2008
    Tulsa, OK
    Default Re: Residential Lightning Protection System Grounding
    My answer is--only if you don't connect the lightning protection system ground rods(electrodes) to the down leads..
    OK--The real answer is no--they are separated systems but must be bonded together..250.106 (2008 ed)
