    Default twistin' the night away
    Could be a record, for me.
    Default Re: twistin' the night away
    John,
    All right if I send that photo to the UL person I am corresponding with about twisted wires in terminals?
    That should surely get a definitive answer.
    Any one in areas which use SE cable have a photo of the outer conductor stripped back, pulled to one side, then twisted back into a stranded conductor I can use?
    How about the markings on SE cable?
    Thanks.
    John,
    Be my guest.
    Aug 2008
    That might not be the photo to refer to. The number of conductors is way over the quantity that the buss is listed for. So we know that would not be correct.
    PS, in the other post you mention terminating shielded cable. SE is not a shielded cable.
    That photo shows two things, one easily identified: too many conductors, the other the twisting, and, if the twisting is okay, i.e., making it into a stranded conductor, then there 'may not be' 'too many conductors' anyway.
    The other post I was talking about SE cable and the outer conductor which is wrapped around it, and that is still the cable I am talking about.
    Go back and re-read what I posted.
    By the way, you never acknowledged your last goof up on code, just, you know, making sure that you know what you are talking about. Or, if you did, I missed in, in which case *I* will acknowledge that, as I do.
    Aug 2008
    So how would you tell if the new conductor was of the proper size to be used in the buss? As long as it fits its OK?
    If asked if wires twisted together from multiple cables were a single conductor or several joined together I would vote that it was not a single conductor.
