Thread: Fitting on JB
    John Stephenson's Avatar
    John Stephenson Guest
    Default Fitting on JB
    James Duffin's Avatar
    James Duffin Guest
    Default Re: Fitting on JB
    While I have never seen one, there could be a fitting that accepts two UF cables. You would need to look at the fitting and see if has two separate holes in the rubber insert. If it has only one then I doubt it would seal two wires properly.
    I know they make those for one cable, but, like James, I've never seen one for two (it's probably made for one and has two in it).
    Did you write up that leaking roof?
    Charles Sessums's Avatar
    Charles Sessums Guest
    See the red stains under the 2x. Thats water traveling Dude.
    Second thoughts. Caulk joints and is that rust on the staple? Jerry? By the way I hate the look at the photo and guess thing.
    John,
    With 6" clearance above it, and with those water stains on that one and not the one sticking out into the wind driven rain more that the inner one, I would suspect the top of the one with the water stains is decaying out (and that decay is causing the staining).
    Just another thought based on the new information about the photo.
