Results 1 to 12 of 12
    Sep 2008
    so so, California
    Mesa, Arizona
    Default Re: Almost didnt get in this panel to see this...
    Oh My Goodness,
    Guess they got tired of the fuses blowing.
    at least they used electrical tape
    Jeff Moore AZ Cert#49250
    Level II Thermographer
    http:www.quantumhomeinspections.com
    Mesa, Arizona
    John,
    I was referring to the wire pieces jumping between poles of the fuse and not the tape alone. The tape seems to be holding the wire jumper to the fuse.
    Jim Zborowski's Avatar
    Jim Zborowski Guest
    maybe they figure if it overloads it willl arc at the ends of the jumper wire, thereby blowing it away and eliminating the connection...................................or, they're just not real bright
    Mar 2009
    Colorado Front Range
    Look at the bright side. The wire will burn in two before the pieces of copper pipe I usually see used in place of the fuses.
    Sep 2008
    so so, California
    I forgot to mention that this was an electricians house.
    I thought John lived in Las Vegas?
    Darin Redding's Avatar
    Darin Redding Guest
    Looks ok to me. At least they used stranded wire
    Dec 2007
    Oklahoma
    As the old saying goes:
    An eletricians house pops fuses
    A plumbers house has leaking pipes
    An asbestos workers house is all dusty ....
    Darin Redding Guest
    Well as HI's, then, what does that say about our HOUSES?
    I probably should move...
    Bob White's Avatar
    Bob White Guest
    Quote Originally Posted by Darin Redding View Post
    Truth.
    If I need a photo of a common problem and don't want to search my photo archives, I can usually shoot a pic of my house....
    Quote Originally Posted by Bob White View Post
    Truth.
    There it is, HIs homes are R&D centers!
