Results 1 to 11 of 11
Thread: AFCI and GFCI Question
06-04-2007, 03:36 PM #1
I did a new construction home today and came across this issue.
The breaker panel has 2 seperate circuits for the bedrooms and they are AFCI protected.
These circuits also feed the master bathroom and the hallway bathroom.
The bathrooms are GFCI protected.
My question is should the GFCI outlets in the bathrooms be fed from an AFCI protected outlet or should they be on thier own circuits?
Thank for your help!
Brian Burns
MHHI
06-04-2007, 04:45 PM #2
Re: AFCI and GFCI Question
Bathrooms should be on their own circuit.
RR
06-04-2007, 05:36 PM #3
06-04-2007, 06:23 PM #4
Si...
RR
06-04-2007, 06:23 PM #5
I thought so,
Thanks alot!!!
Brian
06-04-2007, 08:49 PM #6
Brian,
Thought you might find interesting.
Siemens Introduces Combination ARC Fault Circuit Interrupters
- Paul Fix
06-04-2007, 08:49 PM #7
Yeah... thank's Gerry
RR
06-05-2007, 05:09 AM #8
06-05-2007, 05:47 AM #9
That is correct.
What I found interesting was that with this one detecting arcs at loose connection it seems to have implications for Al conductors. I haven't seen any testing data yet. Wonder if any mfrs have thought about it?
This is major drift. Sorry, Brian
- Paul Fix
06-05-2007, 06:11 AM #10
Richard I mean Rodney how does it feel under the Bus? I mean I get no respect!
06-05-2007, 06:17 AM #11
