Results 1 to 3 of 3
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Distribution panel
    This may have been discussed before but i was unable to located the tread. Is the amount of Romex cable entering the penetration acceptable.
    mike huntzinger's Avatar
    mike huntzinger Guest
    Default Re: Distribution panel
    i would not write it up but if all the wires were sheathed then say somethig
    The extra sheath sticking into the panel is not a big deal, however, your photos show larger problems, such as too many NM cable in a conduit or fitting and not a proper fitting (lower right of panel) and improper fitting with no clamp (lower left of panel).
