Results 1 to 26 of 26
Thread: Spaghetti Bowl
08-21-2009, 06:40 AM #1
Spaghetti Bowl
Ok I am not electrician and electrical is probably my weakest aspect. However, when I see something like this and the electrician on the remodel says it's fine and I am a trouble maker, I had to laugh. I am glad it's Friday. Time for a few Stellas.
08-21-2009, 06:52 AM #2
Re: Spaghetti Bowl
Electrical is my weakest area as well which is why Im curious about the first pic. Did you take that pic because of the knockout that doesnt have a protective sleeve so the wire wont get cut or damaged? Or is it because of the doorbell transformer in the box? If that is indeed a doorbell transformer, i cant be sure
08-21-2009, 07:04 AM #3
08-21-2009, 07:06 AM #4
08-21-2009, 07:06 AM #5
Re: Spaghetti Bowl
you got it. Plus there were two double taps above that but I forgot that photo
08-21-2009, 07:08 AM #6
08-21-2009, 07:15 AM #7
08-21-2009, 07:17 AM #8
08-21-2009, 07:47 AM #9
Re: Spaghetti Bowl
08-21-2009, 07:50 AM #10
Re: Spaghetti Bowl
Possibly
08-21-2009, 07:53 AM #11
08-21-2009, 07:55 AM #12
Re: Spaghetti Bowl
Actually, the door bell transformer does not need its own junction box, it is simply installed incorrectly in that enclosure ... however, installing it in its own junction box would make correction easier and save a LOT of work which would needed to accommodate that mounted in that enclosure.
Also, the low voltage which is in that panel and running to the low voltage transformer needs to be removed and run outside that enclosure.
The transformer could actually be mounted through a knock out in that enclosure with the 120 volt wires inside the enclosure and the low voltage transformer on the outside of the enclosure, with the low voltage wires run outside the enclosure.
Of course, though, if that were down, one would need to make a cut out in the wall and box it in to allow access to and replacement of the transformer, and that drywall being used to box that cut out in would need framing behind it, so ...
It would be EASIER to run a piece of NM cable to a junction box, with a proper clamp at each end, and flush mount the junction box where the transformer is mounted through a knock out in its cover, or, surface mount a junction box where the transformer can be mounted through a side knock out in the junction box, provided there is clearance to the wall to install the transformer (i.e., would require a deep box).
08-21-2009, 08:17 AM #13
Re: Spaghetti Bowl
JP: And that is why I stated that this is where it "belongs".It would be EASIER to run a piece of NM cable to a junction box, with a proper clamp at each end, and flush mount the junction box where the transformer is mounted through a knock out in its cover, or, surface mount a junction box where the transformer can be mounted through a side knock out in the junction box, provided there is clearance to the wall to install the transformer (i.e., would require a deep box).
08-21-2009, 08:21 AM #14
Re: Spaghetti Bowl
08-21-2009, 08:29 AM #15
08-21-2009, 11:43 AM #16
Re: Spaghetti Bowl
08-21-2009, 12:26 PM #17
Re: Spaghetti Bowl
JP: You need to learn to read that old high school dictionary of yours. The definitions are listed (and even numbered) in order of their common acceptance and usage. Those w-a-y d--o--w--n a---t t----h----e
e-----n-----d, you know, down there where you are referring to, are only used on occasion by fringe groups who have chronically been off of their meds.
As to you being more correct than I, we are in agreement, at least in part. You are definitely more something than I am. Exactly what is a matter for yet another debate.
08-21-2009, 12:50 PM #18
Re: Spaghetti Bowl
I am just curious. Can you go through a couple of those "a lot more" problems?
I see a couple of things, but other than being a mess there is not a whole lot "wrong" there.
I am wondering what you all see. (Jerry, you keep out of this one.
I bet one of those dreaded double taps is the chime transformer.
08-21-2009, 01:01 PM #19
Re: Spaghetti Bowl
Aaron,
As usual you are leaving out what you want to, so ... one of the ones I posted was at the same number as yours, which makes yours not applicable (according to you)?
You posted *1* definition to support you.
I posted *3* definitions to support the most common thinking, again, not you.
Now, if my math is correct ... *3* is "lower down" the number chain than *1* is, but ... *3* is a higher number, so that means the list is of more importance as the numbers go up?
Now, as to you being off your meds ...
08-21-2009, 01:14 PM #20
Re: Spaghetti Bowl
Well, for one thing...the 2 previous problems I mentioned which are the doorbell transformer being in the panel(which seems to have sparked quite a debate between JP and AD
) another problem is the knockout in the bottom that doesnt have a protective collar to protect the wire coming in.
Also there appears to be 2 wires in the 2nd 3rd and 4th pic near the top, that have no wire nuts or anything to protect anyone from shock...are those wires live? Are they dead? Im not sure. That plus the entire box appears to be very crowded with wires. Thats enough for me to recommend electrician.
Im sure JP or others can see some problems that I cant see and I would love to know what they are as electrical is definitely my arera where I need the most improvement in.
08-21-2009, 01:23 PM #21
Re: Spaghetti Bowl
JP: As is my prerogative.As usual you are leaving out what you want to, so ...
JP: Those three, not being in first place, all totaled, do not equal the definition if first place. It's an algorithm thing, you know.I posted *3* definitions to support the most common thinking, again, not you.
JP: Yeah, boy. Numbers may not be your forte.Now, if my math is correct ... *3* is "lower down" the number chain than *1* is, but ... *3* is a higher number, so that means the list is of more importance as the numbers go up?
JP: From the horse's mouth.Now, as to you being off your meds ...
08-22-2009, 11:23 AM #22
Re: Spaghetti Bowl
I thought this would be about Las Vegas. "Spaghetti Bowl" is the locals name for the I-15 / I-95 freeway interchange.
08-22-2009, 01:18 PM #23
Re: Spaghetti Bowl
08-22-2009, 01:30 PM #24
Re: Spaghetti Bowl
Whatsa Stella?
08-22-2009, 04:52 PM #25
08-28-2009, 06:56 PM #26
