Thread: What is this
09-03-2009, 03:12 PM #1
09-03-2009, 05:26 PM #2
Re: What is this
Yes, I know what it is ... it is WIRED INCORRECTLY.
Why they wired it incorrectly, that I do not know, but I suspect there was a neutral or ground problem and instead if finding it and correcting it they decided to run a new neutral and ground ... just a WAG.
Of course, if that were the reason for installing it, why not just run a neutral and a ground and not cut off the other conductors???
Which means it 'could have been' for something which was abandoned, so they cut the hot conductors off???
09-03-2009, 05:29 PM #3
Re: What is this
I am presuming you also wrote up the other things which are wrong in there.
09-04-2009, 05:48 AM #4
Re: What is this
Jerry, to me everything else looks okay with the exception of the supply plumbing running in front of the box. What other things are there?
Thanks,
Ryan
09-04-2009, 06:00 AM #5
Re: What is this
Uh, might want to look at the multiple neutrals under one screw.
The unpowered stuff is part of a spa temperature control system and the stuff needs to be removed if not being used.
09-04-2009, 08:06 AM #6
Re: What is this
Ryan,
This is all is visible in that limited photo:
Bill,
