    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Another panel question
    The house was built in 1903, obviously changes were made. This is the service disconnect with a 100amp. The neutrals and grounds are on the same bar, but I could not find an equipement ground. Needed some more eyes
    Inspection Referral SOC
    Default Re: Another panel question
    The grounds that are on the same bar as the neutrals are equipment grounds. Do you mean you didn't see a grounding electrode conductor?
    Aug 2008
    Looks like the GEC is to the left of the PVC conduits. It also looks like you can see where it bends just to the left of the bottom left breaker.
    If you are looking for grounding conductors for wiring run in 1903 it will take awhile. That would pre-date grounded circuits.
    Should have proof read that, yes the GEC. But the house was rewired.
    Jun 2008
    Delmar NY
    This is what Jim pointed out.
    Aug 2008
    Thanks David, exactly what I saw.
    How did you insert those arrows?
    Jun 2008
    Delmar NY
    I got it here.
    Home Whisper Image Edit Light
