Results 1 to 3 of 3
Thread: metal 4"Sq. box
09-11-2009, 11:35 AM #1
metal 4"Sq. box
The NEC code book 2008 edition.
Can a 4"Sq, x 1-1/2" box extension ring be added to an existing
4"Sq. x 2-1/8" deep box.
When finish, I will be installing a 4"Sq., 2 gang, 1" raise, plaster ring so I
can install two switches inside this box. (note: when finish this box will
be cover with sheetrock, expect, the open front, which is where the
switches will be visible.)
Does the NEC allow or probibit this practice?
09-11-2009, 11:42 AM #2
Re: metal 4"Sq. box
Robert,
The NEC will not prohibit you from doing that, but the 2x4 studs, which are only 3-1/2" deep, will prohibit you from doing that.
*IF* you have *NO* protrusions out the back side of the box (you likely will have) then the box and extension ring will be 3-5/8" deep ... in a 3-1/2" deep wall ... ... and then the screws out the back of the box ...
09-11-2009, 01:03 PM #3
Re: metal 4"Sq. box
A big thanks, to you Jerry, with your answer.
When I have a problem, its nice to know, that there people like you
involved with this Form, that can quickly supply the answer I needed.
But what I really like about you, is you go to great lengths to supply a detail answer.
