Results 1 to 20 of 20
Thread: Neutrals and grounds
10-01-2009, 11:27 AM #1
10-01-2009, 12:56 PM #2
Re: Neutrals and grounds
New post
10-01-2009, 12:58 PM #3
They occupy the same bar in the service equipment or main panel.
10-01-2009, 02:34 PM #4
No offense meant, but shouldn't common topics like this be covered in the training courses? Isn't there any requirement to shadow an experienced inspector before doing this on your own?
I commend you for asking questions as that is how we all learn. But how good can the inspection be when the common topics still need to be covered?
10-01-2009, 02:51 PM #5
Couple of black conductors there need to be properly marked as grounded/neutral conductors.
10-01-2009, 03:28 PM #6
10-01-2009, 03:40 PM #7
10-01-2009, 04:13 PM #8
10-01-2009, 04:27 PM #9
10-01-2009, 04:59 PM #10
10-02-2009, 04:20 PM #11
If the wires are feed in thru conduit, I believe you would have to duct seal
around all the wires to seal the conduit openning.
10-02-2009, 04:43 PM #12
10-02-2009, 05:04 PM #13
10-03-2009, 02:50 AM #14
My reply in my last post comes from, the NEC 2008 edition:
300.5(G) Raceway Seals
300.7 Raceway Exposed to Different Temperatures
10-06-2009, 06:45 PM #15
Borrowing the thread for a moment, for today's jewel of a neutral.... I now return you to your regularly scheduled programming....
10-07-2009, 03:37 AM #16
BTW, what section of the NEC governs the splicing of SECs?
10-08-2009, 05:09 PM #17
10-28-2009, 07:32 AM #18
Jerry, Since I'm a little north of you, I'm not familiar with the NEC but doesn't that sentance refer to splicing of the actual feeder cable (ie: extending it) and not splicing the branch circuit wires to the feeder (as in lack of neutral bar) ?
Also, does the NEC allow all the branch circuit wiring to enter and pass through the main-switch compartment ?
Just curious.
10-28-2009, 04:13 PM #19
Joe,
The question was about "service entrance conductors", thus the reference to splices for service entrance conductors, not feeders or branch circuits.
10-28-2009, 05:34 PM #20
Sorry Jerry, I thought we were both talking about the photos in post # 15 above.
