Results 1 to 9 of 9
Thread: mystery items in panel
10-05-2009, 06:21 PM #1
Here's something for some of you to ponder until some smarty pants blurts out the answer.
Hint: It's in a condo.
10-05-2009, 06:35 PM #2
10-05-2009, 07:24 PM #3
Re: mystery items in panel
Some kind of amperage meter?
10-05-2009, 07:35 PM #4
Current transformers, prob. for metering .
10-05-2009, 08:08 PM #5
Those guys are both pretty smart.
10-06-2009, 06:33 AM #6
10-07-2009, 01:23 PM #7
Would you guy's mind being a little more specific as to the actual purpose of these "doughnuts"? Are they for remote a meter reader? Are the common area lights run off of this service and are the "doughnuts" used to measure the difference in the electrical usage between the two loads?
10-07-2009, 05:02 PM #8
It's in a 50 +/- year old apartment/condo building where the tenants/condo owners pay only the electric bill. Apparently, instead of having separate services and power company meters for each unit, they install these current sensors to meter usage.
10-08-2009, 04:48 PM #9
Thanks for the info John, I have a few questions if you don't mind my asking.
I am assuming that in this set up that there is one electric meter and service for x number of units rated at x number of amps.
Questions:
- does the owner/management have a separate bank of sub meters?
- is there a bank of disconnects for the units that are setup this way?
- is a "main breaker" at the panel shown not called for due to the age of the unit?
