Results 1 to 12 of 12
10-06-2009, 10:03 PM #1
Just Curious..What Would You Say??
1965 construction, 100 Amp main panel.
What would you say?
Thanks,
Chuck
10-06-2009, 11:07 PM #2
10-06-2009, 11:56 PM #3
Re: Just Curious..What Would You Say??
I would just say that placing multiple neutral wires under a single terminal screw is considered a safety concern, is a poor connection, and should be addressed. On older homes, I just stick to a common sense approach, since there is no way I am going to research what was allowed back then.
10-07-2009, 05:40 AM #4
I came across the same thing & same make of panel (Zinsco) a week & a half ago,due to the limited # of spots on the neutral bus, the installer had 1 neutral & 1 EGC under each screw, but that was not the only problem in that 1968 house.....
10-07-2009, 06:32 AM #5
I would report neutrals and grounds on the same buss if it is a distribution panel. If it is a service panel, that is OK.
But I would report two grounds of different sizes under a single screw. I would report more than one neutral under a single screw.
10-07-2009, 07:36 AM #6
10-07-2009, 07:44 AM #7
It is also a Zinsco panel and that is a problem all in itself!
10-07-2009, 08:39 AM #8
10-07-2009, 01:58 PM #9
10-07-2009, 02:59 PM #10
10-08-2009, 07:58 AM #11
10-08-2009, 06:07 PM #12
If Billy gets ahold of that photo you're in BIG trouble Look what he did to me! HAEEHAW
