Results 1 to 3 of 3
10-07-2009, 08:42 AM #1
wire to garage feed from from pump circuit
I just observed, were the wiring for the garage was fed from the 240 circuit that feeds this house submersible pump. The breaker is a 120/240. 20 amp., double pole.
Now, even if there was a neutral grounded wire available at this location, is there any thing that would prohibit this practice in the NEC 2005 or NEC 2008, I been looking, but haven't found it yet.
Thanks!
10-07-2009, 08:59 PM #2
Re: wire to garage feed from from pump circuit
I don't know the code rule, but it is simply bad practice to put any other load on your well pump feed. A garage is likely to see some higher loads from power tools, etc. It is wrong, and asking for trouble. Hope this helps a bit.
10-13-2009, 06:58 PM #3
John Kogel
Thanks for your reply post answer to my question. I agree with you.
And so noted, in the report.
