Results 1 to 16 of 16
Thread: Under-Cabinet Lighting Splitter
11-03-2009, 10:41 PM #1
Kitchen under-cabinet lighting is tied into a splitter that is plugged into the outlet. The microwave is plugged into the other plug at the duplex outlet in the cabinet above the microwave.
1) Is this splitter an "approved" device?
2) The under-cabinet lighting is ungrounded (two wires) and is not GFCI-protected in locations near the sink. Would you recommend repairs or removal?
(Yes, I noted the open splice in the one wire.)
Similar Threads:"Baseball is like church. Many attend but few understand." Leo Durocher
Bruce Breedlove
www.avaloninspection.com
11-03-2009, 10:51 PM #2
Re: Under-Cabinet Lighting Splitter
Bruce,
Boy, that is pretty weird looking. I would certainly recommend corrections.
11-04-2009, 07:53 AM #3
Looks like a flexible multi-tap adapter that you can buy at the hardware store.
If the microwave instructions called for a dedicated circuit you would have a technical violation as it is now being shared with the lighting.
There is no requirement for the lighting to be GFI protected.
11-04-2009, 01:29 PM #4
Those stupid line-voltage puck lights are bad on many levels, but hey, they are easy for Harry Homeowner to install.
11-06-2009, 04:47 PM #5
11-06-2009, 06:18 PM #6
11-06-2009, 06:24 PM #7
11-06-2009, 06:52 PM #8
Huh?
An "upgrade" is not a "repair" or a "correction".
Like this:
- I'd like to buy that car but with a radio which has a CD player.
- No problem, that is just a simple UPGRADE, it only costs ... more.
Or this:
- I'd like you to repair my car radio, it is not working.
- No problem, and if that radio is not repairable we can replace it with the same thing.
- Well, if you are going to replace it, I would like one with a CD player.
- No problem, we can UPGRADE the radio to one with a CD player when we replace it, it only costs ... more.
You are in Canada, so I'm not sure what language you are speaking.
11-06-2009, 07:07 PM #9
The light's not broken, how can it be repaired? To "correct" that installation, plug it into another outlet that is not designated for the MV.
To improve that temporary situation, "upgrade it".Neither am I, eh?You are in Canada, so I'm not sure what language you are speaking.
11-06-2009, 07:09 PM #10
11-06-2009, 07:14 PM #11
Jim,
I did, and what he should have said was to have it repaired.
That is a deficiency and reportable.
THEN he could have added something about an "upgrade", but by simply stating to "upgrade" it, there is no deficiency to report, and if there is no deficiency, why "upgrade" something which is okay?
The only way the client benefits is for home inspectors to report deficiencies as such, not to call them "maintenance" or "upgrades".
I have seen reports where EVERYTHING was an "upgrade", even the leaky roof with shot shingles.
11-06-2009, 09:33 PM #12
11-07-2009, 06:09 AM #13
Since when is something that needs maintenance a deficiency?
11-07-2009, 10:57 AM #14
I don't think JP said that it was, just that we should not call for maintenance (or an upgrade, either
) when there is a deficiency.
This plug-in lighting does not meet code standards of today, so Jerry says it is a deficiency, repair it.
I am not sure when the lighting was installed, and if it was ever acceptable in that jurisdiction, so I am backing away slowly.
We don't tell people they need to repair the wiring if the installation was code compliant when installed. However, if they were to unplug these lights, they're apparantly not allowed to plug them back in!
I'm outta here.
11-07-2009, 03:34 PM #15
John Kogel, your post dated: 09/07/09
"This plug-in light does not meet code standards of today".
What light are you talking about?
I look at Bruce Breedlove photo, and saw no luminaire.
And what code are you talking about?
How you don't mine my questions, but I am on this site to learn, so a
little help here, please.
11-07-2009, 04:29 PM #16
Bruce Breedlove
