Thread: Grounding wire
12-22-2009, 02:55 PM #1
Grounding wire
Hey guys.... had one today... service panel grounding wire has been cut... couldn't find the rod either.... noticed the neighbors house was the same... any idea what's going on? b
12-22-2009, 03:27 PM #2
Re: Grounding wire
Scrap copper acquisition or an accessible tail to allow the utilities to connect to the grounding system.
12-22-2009, 04:53 PM #3
Re: Grounding wire
Overzealous or clutzy landscaper doing the back fill and grading might have hooked the gec and burried the rod(s).
12-22-2009, 05:11 PM #4
Re: Grounding wire
Was it grounded to plumbing at the inside?
Outlets showed as grounded right?
Maybe the developer did an alternative.
I see the Cable or Phone company had no problem running their ground to it (green wire).
12-22-2009, 08:02 PM #5
12-22-2009, 08:04 PM #6
Re: Grounding wire
Maybe the utility company upgraded the water supply lines to the homes in the neighborhood, going from medal pipe to plastic tubing. They may have cut the grounds on the homes in the process (if they were were using the supply lines as a ground or if they assumed they did) and never informed the home owners of this. Or they informed the home owner but nothing was done to install a new ground. Or the utility company was responsible for installing a new ground but never did. Just a thought.
Take care, Dustin
12-22-2009, 08:32 PM #7
Re: Grounding wire
12-22-2009, 08:48 PM #8
Re: Grounding wire
Agreeing with Jim Port?
WHO are you - and what have you done with th real Jerry Peck?
