Results 1 to 16 of 16
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Messy Workmanship In Panel
    Just curious how often you mention messy workmanship in panels. The pics are not the best I had to crop them, but you get the idea.
    Default Re: Messy Workmanship In Panel
    I've seen some proverbial rats nests in panels but unless there is something wrong, I don't write it up. However, I have written it up when the wires won't even stay inside the front of the box interior with the deadfront cover removed.
    Given what I usually see, it would never occur to me to write those up as messy. It's all relative, I guess.
    Well after I saw this I just figured the guy was having a bad day
    That I would write up.
    ditto
    Oct 2009
    michigan
    No code violation that I can see from pics.
    Visually messy is not a hazard in most cases because; in most cases there really isn't sufficient room for a neat installation especially when the neutral/grounding busses are located at the top of the panel.
    Whenever I encounter a real neat job, usually all the conductors are tie-rapped together, I make the installer cut em off and spread them out...making it more messy.
    I really appreciate when the conductors are neatly cut exactly to length so that a bunch of wire nuts can be installed at the next service upgrade.
    Bob Smit, County EI
    Oct 2009
    michigan
    Whoa, didn't see that last pic at the bottom of the panel :{
    Bob Smit, County EI
    Jeff Remas's Avatar
    Jeff Remas Guest
    I will up the ante on this one. You should have seen the rest of the house.
    It was classic "Deliverance meets Red Green"
    Quote Originally Posted by Jeff Remas View Post
    Yes that one's a classic. Things went all to h3ll after he lost the screws to the deadfront.
    John Pignatore's Avatar
    John Pignatore Guest
    I address violation and unsafe conditions..if I were to start addressing messy workmanship, I would need 10 hours on some inspections...
    Santa Fe, NM
    I'll raise you three!!!!!
    You did say you wanted the panel plastered too????
    Charles @ PreVue Property Inspections, Santa Fe, NM
    http://www.prevuepropertyinspections.com/
    "How can someone with glasses so thick be so stupid?"
    May 2009
    Pennsylvania
    We probably all have some messy panel boxes, which seems to be the norm. So when I see a well kept panel (no code issues, no rust, etc,) I like to make a general comment as a good will jesture, like "well maintained panel box". It makes the owner "feel good" and the buyer is glad to have a good panel.
    Sep 2007
    Fredericksburg, VA
    Quote Originally Posted by Chuck Miller View Post
    If the wiring in the box is another indicator of amateur DIYitis with the electrical system,I have advised having a master electrician check and correct all wiring issues in the house as a safety precaution
    Stu, Fredericksburg VA
    Mar 2009
    Utah
    I have seen a lot worse but I usually only write them up if I can't read the legend or if the panel is really hard to close after removing the front, or there is some other problem with the wiring.
    Bill Barnes's Avatar
    Bill Barnes Guest
    Thumbs down Re: Messy Workmanship In Panel
    Hey Charles, At least the had the breakers installed when they spray textured.
