Thread: Panel installation
02-22-2010, 05:18 PM #1
Panel installation
Please tell me that installing the panel cover ontop of the metal siding used as a wall covering as gotta be wrong...if the panel become energized somehow, then that metal wall covering would become energized , correct...this has gotta be wrong, right?
b
Similar Threads:Last edited by brianmiller; 07-02-2013 at 04:40 PM.
02-22-2010, 07:20 PM #2
Re: Panel installation
If the enclosure projects as far through that metal as it should, there should not be a problem. After all, the enclosure IS (supposed to be anyway) GROUNDED, and the cover properly mounted to the enclosure is also grounded. And I would want that metal siding grounded too.
02-22-2010, 07:42 PM #3
thanks, jerry...I'll ponder your response for awhile....
b
02-22-2010, 09:50 PM #4
