Thread: Double Taps
    Dec 2007
    Holladay, UT
    Default Double Taps
    How can you tell which Square D breakers are designed for two wires at screw down?
    http://acloserlookslc.com/
    Default Re: Double Taps
    If you got really, really good eyes, you might be able to read it on the breaker, or you can look at the terminal clamp.
    Aug 2008
    Sq D 15-30 amp breakers are listed for one or two conductors. Larger sizes are for one conductor only.
    Jun 2008
    Here is whats printed on the side of the SQ-D's.
    Jun 2008
    That pic was too small. Here's another.
    Chap Fichera's Avatar
    Chap Fichera Guest
    But that's only for the same gauge wire on each breaker?
