Results 1 to 3 of 3
Thread: copper wire
06-29-2007, 05:01 PM #1
copper wire
This is a down stream panel. Is that copper wire from the neutral buss and under that screw a bond? All grounding conductors are under a lug hidden behind that circuit wire that’s taped because taping must be easier than cutting to the right length. I need a quick answer if someone has one.
I have to send this off tonight. Thanks.
Similar Threads:The only reason some people get lost in thought is because it's unfamiliar territory.
- Paul Fix
06-29-2007, 05:38 PM #2
Re: copper wire
Thom,
It certainly looks like it. One thing I can't tell is if the neutral and the ground bars are tied together.
Either way, if this is down-stream, it is wrong.
Rich
06-29-2007, 06:03 PM #3
Re: copper wire
Thre is only the one bar that you see. First time I've ever seen this and wondering what he is doing. Thanks for the response.
- Paul Fix
