Results 1 to 12 of 12
Thread: What is this device?
03-24-2010, 12:50 PM #1
Hi everyone, this is my first post here, just found the site. Anyways can someone here tell me what the item is in the attached picture. The item I am referring to is in the smaller box next to the main panel labeled 200 in yellow letters. I have never seen this before, there is two meters outside and it appear this has something to do with it. I have never seen two meters on one house before and none of the other houses on that block had two meters like this.
Thanks for looking
Pete Busch
Similar Threads:Last edited by Pete Busch; 03-24-2010 at 12:51 PM. Reason: forgot to add something
03-24-2010, 01:00 PM #2
Re: What is this device?
It is an ABB current transformer.
03-24-2010, 01:05 PM #3
As said already, it's a CT I would guess it has something to do w/ the 2nd WHM (cash register
) in the last picture.
Edit: My guess this gear is tied to the air conditioning & the box above the meter is for PoCo to remote control the A/C.
03-24-2010, 01:05 PM #4
Ok, why is it there and what is its purpose?
03-24-2010, 01:09 PM #5
03-24-2010, 03:41 PM #6
Google "ABB Type CSF Transformer" and you get from ABB
The CSF is a miniature current transformer used for indoor and outdoor metering applications. Used with watthour meters, it is applicable to single or multiphase low voltage circuits. The CSF is used with flat and high bases and brackets such as the TMB-3.
Stu, Fredericksburg VA
03-24-2010, 04:36 PM #7
03-24-2010, 04:41 PM #8
03-24-2010, 06:33 PM #9
Did you happen to notice what the circuits feeding through the CT were supplying power to? That info may help understand why it is there.
03-26-2010, 09:55 AM #10
That sounds right - in my area the PoCo has a program to reduce your rates if you have one of these devices on your equipment; that way during peak periods the PoCo can cut power to certain areas of the city, certain types of loads, etc. - So, for 365 days a year you get a discounted PoCo rate in exchange for a couple of days [maybe] of reduced power to certain types of loads.
03-30-2010, 04:26 AM #11
Peak demand cycling for AC or Heat pump Condensor and/or electric water heater, etc. "Load Management" program.
Transformer is part of the CT metering system.
P.S. Guess we don't need to say anything about the drywall/panel cabinet installation issues
03-30-2010, 05:25 PM #12
That was left open so we could see the nail protector plate.
I know, it is not just the gap and space around the panel enclosure but the fact that the panel is set back in at or beyond the inner face of the drywall when the maximum recessed amount with gypsum board is 1/4", and ...
... it does extend out beyond the combustible stud ...
Be that as it may, it may be a good issue to discuss for those who are not aware of it.
