Results 1 to 3 of 3
    Montreal, Quebec
    Question Wiring & Sprayed On Insulation
    Is there an issue with spayed on insulation coating wiring, even next to the main panel?
    Aug 2008
    Default Re: Wiring & Sprayed On Insulation
    From the Icynene website FAQs.
    Any Electric Wiring Overheating Problems?
    No, Icynene® insulation has been tested and found to be safe. It has been applied over electrical wiring for over twenty years.
    I have not seen anything during a code update class that treats this any different than fiberglass insulation.
    David Bell's Avatar
    David Bell Guest
    The builders I deal with the most do not spray the bay the panel is in to ease future wiring or repairs.
