Results 1 to 3 of 3
    Apr 2009
    Manchester, Vermont
    Cool calking used on electrical wires
    Hello:
    I have question for you, out there, what in your opinion is the best material to used, around an SE-R cable that run from the exterior
    disconnect thru a drill, that allow the SE-R cable to enter the basement
    of a home. I see a lot of duck seal product, but I want to know if anyone
    knows of anything better than duck seal. Thanks in advance to all who
    take the time to answer this post.
    Default Re: calking used on electrical wires
    john_opwin's Avatar
    john_opwin Guest
    Mostly electrical wires are affected by externally environment such as corrosion, acid rain and ultraviolet rays. You have to apply the cover on wire which can resist water and fogs from environmental.
    Example:
    optical fibers ( that is highly protected).
