    Ron Bibler's Avatar
    Ron Bibler Guest
    Talking Exposed and unprotected wiring
    Would you call this as an unprotected and exposed wiring condition.
    Location Sub-structure. Damp soil with NM cables all over the place.
    Brain dead today...
    Best
    Ron
    Default Re: Exposed and unprotected wiring
    Quote Originally Posted by Ron Bibler View Post
    No, I don't use 'condition' in my inspection report.
    Yes, I would call out the wiring wrapped around plumbing pipes and squeezed through hole with a heat duct. In my report, that's a " * Repair * ".
    Brain dead today...
    I'd recommend a brain protector for those crawlspaces.
    dana1028's Avatar
    dana1028 Guest
    I see lots of violations among the photos, but I am curious: What 'repair' would be made for the NM cable wrapped around the copper pipes and those passing through the same hole as the heat duct?
    I mean, what code section would you use the substantiate the 'repair'?
    Quote Originally Posted by dana1028 View Post
    I mean, what code section would you use to the substantiate the 'repair'?
    We still use 'code of the west' where I live.
    I just know it's unsafe, and I know it is preventable, therefore repairable. An electrician might have to go back to the nearest junction and pull the wire so it's hung properly.
    If we keep this post active someone will come up with the code.
    Ron Bibler's Avatar
    Ron Bibler Guest
    Did you see the notched framing ?
    Best
    Ron
    Aburnell's Avatar
    Aburnell Guest
    That must have been done in the dark.
    Thermostat
    dana1028's Avatar
    dana1028 Guest
    What specifically are you considering unsafe? The conductor touching the metal water pipe? The conductor touching the metal ducting? The conductor in the same cavity as the ducting?
    "Hung properly" - I cannot determine from the photo that the wire is not 'hung properly'. NM cable is required to be secured within 12" of termination and every 4 1/2' otherwise....there is not enough of the photo to determine that the NM cable does is not secured within these parameters.
    Conductors are allowed to touch metal water pipes - as the copper water pipes are required to be bonded to the service - so any possible fault will be cleared.
    Conductor touching the metal ducting? The NM has an equipment grounding conductor to clear a fault should one occur.
    Conductor in the same hole/cavity as ducting? So what.
    There are 1000's of 'I don't likes' I observe during my inspections [municipal inspector] - but I'm not allowed to whilly-nilly demand contractors change things because I don't like it; I have to be able to provide a specific code section.
    Notched framing - as I said, I see lots of violations in those photos....just having a hard time with the particular photo of conductors passing through the floor at the ducting. Do I like it? Probably not; would I pass it?.... I don't see that I have a choice....but I'm more than willing to change that opinion if someome can give me a code section to stand on.
